Kompresori i alternative
Idi na stranicu Natrag  1, 2, 3, 4
Herr Flick
PorukaUpisano: Čet Stu 10, 2005 12:57 am    Naslov poruke: Citiraj ovaj komentar
ides koja ideja... samo susjedu trebam copit gumu sa stare stojke, ta vozi i na tri kotaca Laughing
a evo jos jedna ideja: mozemo mi prikljucit airbrush na onaj kompresor na benzinskoj i onda tamo bojat Laughing
trut
PorukaUpisano: Čet Stu 10, 2005 10:53 am    Naslov poruke: Citiraj ovaj komentar
ma koja guma.... fino se doma nazderes graha sa sedam kora. crijevo u packshoe i udriiiii... Vrag na vatri Bacac plamena
stalan pritisak, tlak preko 4 bara, troskovi minimalni, jedini je bad opasnost od eksplozije. i naravno, treba ugradit filter protiv krutih cestica u mlazu Razz
Ice Demon
Član od: 26 Pro 2006
Poruke: 383
Mjesto: Marija Bistrica
PorukaUpisano: Sri Pro 27, 2006 6:48 pm    Naslov poruke: Citiraj ovaj komentar
Jako su skupi oni kompresori, no mislim da je to u skladu sa njihovim mogucnostima, imaju sve...
skobe
Član od: 29 Stu 2006
Poruke: 567
Mjesto: zagreb
PorukaUpisano: Sub Pro 30, 2006 12:15 am    Naslov poruke: jel valja ovo ista od ovog? Citiraj ovaj komentar
REVELL 39137 Kompressor "Standard Class"
The 'standard class' compressor is an oil-free piston compressor. It works best with our 'standard class' spray-gun. It is ideal for ambitious beginners.
Type: Oil-free piston compressor (220 - 240 V / 50 Hz / 135 W)
Maximum pressure: approx. 5.5 bar
Output in litres of air: approx. 23 l/min
Noise level: approx. 55 db
Extras: Manometer, pressure regulator, water separator, automatic switch-off system, carrying handle.
Connectors: Fitted as standard with the connector (1/4 inch) for hoses 38230 (with compressor adapter) and 38250. The compressor adapter is included, but the hoses are not included in the set.
ili
REVELL 39138 Kompressor "Master Class"
The 'master class' compressor is an oil-free double cylinder piston compressor. It works best with our 'master class' spray-guns. It is ideal for airbrush pros and all airbrushing work.
Type: Oil-free piston compressor (220 - 240 V / 50 Hz / 145 W)
Output in litres of air: approx. 32 l/min
Air tank: approx. 2.5 l
Noise level: approx. 50 db
Extras: Double cylinder, 2 manometers, pressure regulator, water separator, air tank with condensation drain valve, safety valve, automatic switch-off system, carrying handle.
Stranica 4/4
