avion u letu
Sivcev
Član od: 18 Lis 2005
Poruke: 346
Mjesto: Novi Sad
PorukaUpisano: Uto Stu 18, 2008 11:07 am    Naslov poruke: avion u letu Citiraj ovaj komentar
nisam siguran da to ovde spada ako ne moderatori neka premeste topic
Ovo je copy/paste text sa mailnig liste o airliners maketarima. Svidela mi se ova fora da se prikaze maketa aviona u letu a da ne bude na postolju, slike sve govore, uzivajte.
Latest one out of the Hangar: B-727-200
Posted by: "oldHooker" fwhite@gunsagogo.org hey0verhere
Date: Sun Nov 16, 2008 6:05 pm ((PST))
Hi all,
Recently completed a commissioned build of a Hasegawa 1/200 Lufthansa
Boeing 727-200 MID, and thought I'd share the pictures. (it's been
cloudy & rainy & couldn't make any outdoor/blue sky shots, but just
as well)
Here's a couple showing the half plane connected to a "back-board"
while being worked-up.
Scratched undercarage....
I mounted it in the prototype MID display case in Take-Off
configuration, with the gear about 3/4ths retracted.
Backdrop BEHIND and to the SIDES, so much of the glare goes away.
There's another positive aspect of displaying in the case; using END
mirrors to "open-up" the scenery. They can't be too high or they will
show the plane, but they make the runway (or whatever surface they're
applied to) extend beyong the boundries of the case. The down side
is "shadows", if there's not a light source directly over or in front
of the display, however, the light source makes a shadow of the
plane, so using it on a dio where the plane's in close proximity to
the ground works out great. I just held that small mirror to the
outside of the case to illustrate what I'm talking about....
(here you can see where I was careless and sanded some of the seam
away)
Take care,
Frank
Maketarski klub "Novosadski Ikar"
PorukaUpisano: Uto Stu 18, 2008 11:19 am    Naslov poruke: Citiraj ovaj komentar
Luda ideja! Ovo treba zapamtiti i primjeniti. Exclamation
Mario Raguž
Poruke: 1284
Mjesto: Dubrovnik
PorukaUpisano: Uto Stu 18, 2008 11:39 am    Naslov poruke: Citiraj ovaj komentar
Moram priznati da je ideja i više nego dobra! Hvala
Svi smo mi Marko Babić
PowerPlant
Član od: 02 Svi 2007
Poruke: 3207
PorukaUpisano: Uto Stu 18, 2008 12:32 pm    Naslov poruke: Citiraj ovaj komentar
Shocked
Koja dobra ideja Laughing
Avioni me nimalo ne zanimaju ali ovo stvarno odlicno izgleda Cool
Igor_A.
Član od: 03 Tra 2008
Poruke: 307
PorukaUpisano: Uto Stu 18, 2008 12:45 pm    Naslov poruke: Citiraj ovaj komentar
Jednom sam, sad se ne mogu sjetiti kad i gdje, vidio da se prodaje poludovršena maketa aviona, mislim da je bio neki stari dvokrilac, ali najveće iznenađenje je bilo u tome što je maketa predviđena da "lebdi" iznad postolja. Maketa nije bila sastavljena, nego zapakirana u kutiju. Očito se u postolju i modelu nalaze magneti koji se međusobno odbijaju. čini mi se da sam to vidio u Turbolimaću na Žitnjaku, pred nekoliko godina, ali kao što rekoh, nisam siguran, možda netko zna nešto više?
PorukaUpisano: Uto Stu 18, 2008 12:56 pm    Naslov poruke: Citiraj ovaj komentar
Igor_A. Napisao/la:
U pravu si. Bio je to Fokker Dr.I sa nekakvim magnetnim postoljem.
PorukaUpisano: Uto Stu 18, 2008 12:58 pm    Naslov poruke: Citiraj ovaj komentar
PowerPlant Napisao/la:
Shocked
A što kažeš na dioramu akcijske scene iz filma gdje neka opaka pila/auto leti po zraku?
PowerPlant
Poruke: 3207
PorukaUpisano: Uto Stu 18, 2008 1:16 pm    Naslov poruke: Citiraj ovaj komentar
Grunf Napisao/la:
Shocked
Odmah mi pada na pamet ona scena iz "The Man With the Golden Gun" Bonda kad AMC Hornet prelijece onu rijeku okrecuci se za 360 stupnjeva oko svoje osi Laughing
U svakom slucaju, bila bi to strasna diorama Wink
Shmeegy
Član od: 09 Kol 2007
Poruke: 1768
PorukaUpisano: Uto Stu 18, 2008 1:28 pm    Naslov poruke: Citiraj ovaj komentar
Ludnica je ova ideja sa avionima!
strasna je ta scena.. predobro bi zgledala ta diorama kad bi se kvalitetno izvela! Very Happy
PorukaUpisano: Uto Stu 18, 2008 2:07 pm    Naslov poruke: Citiraj ovaj komentar
A najbolje od svega je što se na ovaj način mogu od jedne makete napravit dvije, sa različitim oznakama!
PorukaUpisano: Uto Stu 18, 2008 2:13 pm    Naslov poruke: Citiraj ovaj komentar
Boris G. Napisao/la:
Dakle, sa jedne strane napraviš P-47D u US oznakama, a sa druge u njemačkim nakon zarobljavanja (po mogućnosti isti avion) i nazoveš dioramu Dr. Yekill i Mr. Hide. Wink Cool
Sivcev
Poruke: 346
Mjesto: Novi Sad
PorukaUpisano: Uto Stu 18, 2008 2:18 pm    Naslov poruke: Citiraj ovaj komentar
Malo pre sam stavio jednu polutku trupa na ogledalo i desilo se to da debljina ogledala (reflektujuca povrsina je na dnu ogledala) kvari celu pricu jer se za tu debljinu javlja "zazor" izmedju trupa i odraza na ogledalu. On je izgleda koristio neku super reflektujuci foliju e sad koju???? ili je nesto drugo u pitanju, super tanko ogledalo mozda??? ne mogu da provalim.
Sivcev
Poruke: 346
Mjesto: Novi Sad
PorukaUpisano: Uto Stu 18, 2008 2:48 pm    Naslov poruke: Citiraj ovaj komentar
Isti covek, slicna tema
Hi folks,
Here are some pictures of the Air France Caravelle "MID" display I
finished up a couple days ago, which follows the Construction
Illustrations I posted earlier.
I used half of a 1/200 Heller Caravelle for the center piece, and
the wood/mirror from Flyteline Models forthcoming 'Kit1".
(the "mountains" started their life as one side of a styrofoam
cooler! Wink Enjoy
"Patent Pending"
Take care,
Frank
jos njegovih ideja
The MID (mirror image display) technique.
It was suggested that I have a Patent Search done on this type
display technique, which I accomplished through a Patent Lawyer,
and it only returned 15 relavent results; NONE of which even
came close! Filed an Application and recieved an official
Patent Number on July 14.
Signed a contract with Flyteline Models, Inc. on July 15th for
them to begin manufacturing this technique! Yes, one of
them "dream come true" scenereos!
Sivcev: poruka promijenjena dana: Uto Stu 18, 2008 3:37 pm; prepravljeno ukupno 1 puta
Sivcev
Poruke: 346
Mjesto: Novi Sad
PorukaUpisano: Uto Stu 18, 2008 3:12 pm    Naslov poruke: Citiraj ovaj komentar
I jos.....
Greetings all,
This dio has been a dream in my head for a long time, so on Sep.
2nd I decided to make it a reality; finished it at 4am this morning!
(finishing touches kicked my butt)
I used the Airfix 1/300 B744 as the subject and Flyteline Models new
MyDIO kit#1 to mount it. The landscape was accomplished using
styrofoam and the water using Testors Clear Cement & Windshield
Maker. All the other details were scratchbuilt, so no aftermarket
parts were harmed. Smile Enjoy!
Oh... and no aftermarket parts were harmed during the construction
of this model. Wink
Take care,
Frank
Sivcev
Poruke: 346
Mjesto: Novi Sad
PorukaUpisano: Uto Stu 18, 2008 3:19 pm    Naslov poruke: Citiraj ovaj komentar
nastavak
"blurovanje" piste
Stranica 1/3
